Results 1 to 10 of 10
    Jun 2005
    I've been perusing through the Residential and Wall of Pride forums and have a question about condensate trapping on condensing furnaces. If the condensate is draining from furnace through 3/4" piping and into a pump, would a drain trap still be necessary? This an upflow system, a-coil on top, and condesing furnace. I haven't seen alot of pictures in the wall of pride section showing drain traps on some 90% units and was wondering what people are doing.
    Apr 2005
    NE PA
    You should have a trap in almost all instances.
    Read: http://www.trane.com/commercial/issues/iaq/iaq5.asp
    for the long story on traps.
    paul
    midwest
    There is a trap in all 90% furnaces already so I never trap them again.
    burlington county n.j.
    what trane said
    S.W. PA
    long answer made short you PROBALLY do not need a trap if you are using a 90+ and a condensate pump
    however a trap would not hurt
    Thanks for the article. I'll be putting a trap on this weekend.
    midwest
    Great, now all 90,s are going to be double trapped. It won't hurt but it also won't help. All you are doing is adding a likely place for the drain to cause future problems.
    Jun 2005
    I see. Thanks everyone for clarifying.
    I have an 80 and no trap between the humidifier and condensate drain. My drain is plumbed directly into the sewer and there is a trap there, but it has occoured to me that since there is an opening at the humidifier where air can be sucked in, and a place for it to go into the air handler through the drip tray, that I need another trap.
    I've been told when using a condensate pump, no trap is needed. Therefore, I've never installed one when using a pump. If this is incorrect, please clarify so I can correct this.
    Get back to work.™
