Results 14 to 19 of 19
Thread: A/C sizing
    May 2002
    Colorado
    Originally posted by uktra
    Mrbillpro--If you look at some of the Building America homes by Pulte in Houston you will see about 1 ton per 1000 sq. ft. It's all in the way you build the home.
    And design, install and commission the HVAC system.
    Good job Panama--I should have included that!!
    What I’m attempting to say is do not focus on capacity numbers, but rather on compliance with the vendors specifications. Does this make sense?
    Absolutely, so the next question is where do you go to find the vendors specs without having to ask anyone...just trying to filter out diff opinions of diff HVAC contractors, so as not to confuse opinion with fact...thanks
    SW FL
    Question Learn from the ' Best '
    you will see
    UKTRA,
    Please provide link to specifics like Floor Plan,
    Window Area, S.H.G.C., U-value, Insulation values, ...
    Now that's something WE Can ALL Learn from:
    1,000 Sq. Ft./Ton
    Does anyone else in Houston build to that level?
    I'd like to know how to get just half way there...
    800 S.F./Ton
    Designer Dan
    Look up DOE's Building America site. Also [url]http://www.buildingscience .com
    SW FL
    Thumbs up
    I appreciate it
    Designer Dan
