Results 1 to 13 of 33
    Lately, i have been measuring voltage on the top of combo Run Capacitors that far exceed the voltage rating stamped on the Run Capacitor furnished with the Goodman A/C unit.
    IE: Todays measurement :
    Goodman 2 ton model CK24 unit . Rating of combo run capacitor : 370 v. Voltage as measured on top between common and Herm : 389 v. Unit was operating correctly and incoming voltage entering and leaving the Contactor was 245 v.
    Over the last few weeks, ive measured even greater variances on Goodman A/C Combo Run Capacitors between common and Herm as well as common and fan .How come they didnt put in 440 v. rated Combo Run Capacitors ?? Ive also had quite a few Combo Run Capacitors blow over the last few years on Goodman ... most likely due to the higher voltage imposed on them , than what the rating is.
    Anyone else running into this ?
    Dave
    Jun 2001
    Anyone else running into this ? Yes
    I usually go ahead and grab a 35/5 440 off of the truck.
    How can a Manufacturer not pick this up in their R&D ??
    RoboTec..if youre still with Goodman, whats your take on this problem ???
    Sep 2001
    angola indiana
    run caps
    I too have replaced many,many run caps on goodman condensers. I always repcace with 440 .
    Thats what i do also.
    Midlothian, Virginia
    how?
    if a capacitor can be thought of as a balloon and voltage a pressure. (electrical pressure that is) how can what you guys see occuring happen. the balloon ( capaacitor in this case) can't have higher pressure than the thing pumping it up. (the line voltage in this case)
    Goodbyee stranger it's been nice. Hope you find your paradise! Hey it aint rocket science, "It's a Trade !"
    The voltage across the cap is from the start winding, not the line voltage.
    Hell Hole Swamp
    The caps blowing up is a GE problem, they do this on every manufacturers unit in which they are installed, not just Goodman, the compressor manufacturer specs the run caps anyway
    'The caps blowing up is a GE problem, they do this on every manufacturers unit in which they are installed, not just Goodman, the compressor manufacturer specs the run caps anywa
    ME: Not just GE caps either ; have found other brand caps where the voltage on them are considerably above the rating. Youd think these residental Compressor Mfg'rs would just go with all 440 v. rated caps, and be done with it.
    Feb 2005
    GEORGIA
    Oh, beenthere...
    You could take most of "us" back to school..
    This is very much understood...
    Peace,
    Stephen
    "Value our Differences"
    ok the voltage across the start winding is the voltage across the start capacitor.
    and guess what the voltage across the start winding is the line voltage.
    Not quite, but close.
    All motors are generators, and all generators are motors.
    The voltage from the start winding is an EMB, with is higher then the line voltage.
    Correct. A motor is like a generator in that it generates higher voltage known as BEMF or Back Electromotive Force ; This increased generated voltage comes thru the start winding and thru the wire leading to the Run Capacitor terminal . The other terminal on the RUn Capacitor is for the Run winding on the compressor (or fan motor...as the case may be). The rating of a Run Capacitor , such as 370 volts...must not be exceeded during operation. Its common to find Goodman A/C units all the time where the imposed BEMF voltage is higher than 370 volts. I think the highest ive ever found was over 400 volts .
