Thread: HELP
    Jun 2005
    Hmm
    HELP! I HAVE AN AIR CONDITIONING SYSTEM THAT I ABSOLUTLY HATE AND HAVE HATED SINCE I MOVED IN 10 years ago!
    This stupid thing in mounted in the attic (were the heat built up is unbelievable) and it gets to the rooms by means of TUBES. Problem is I can barely feel the air moving and it doesn't cool a damn thing, even after having te outside unit replaced. HI VOLUME AC??? I think not! Any suggestions as to what the problem might be? If it is 79 degree's out side and sunny, it can't even get the temp under 74 degrees.
    HELP!!!!!!!!!!!
    check your return are filters may need to be changed if it is not that u need to call a tech out to fix it
    Jun 2005
    Unhappy ALREADY DID Check the return.
    Even if I take the filter OUT (to clean it) it still doesn't move any air...I know that the blower is working but it is not sending the air where it needs to go!
    Ductleaks ,dirty coil and blower,could be amoung the reasons.
    When is the last time it was serviced and cleaned?
    Jun 2005
    Hmm
    Need to find someone in the Des Moines area who knows how to check this thing. My guess is a major duct leak. Any suggestions on people? What about John Rounds at Excel or Rob Henriksen?
Comfortech365 Virtual Event
