    Apr 2011
    Joliet IL
    baxter 300g oven rotisary wont stop
    im trying to find a schmatic for this oven and some advice the rotisary will not stop when the doors open ive tried to adjust the door switches i have replaced the relay the old won was welded together and trying to get parts or help from hobart and baxter is impossible
    Over the river and through the woods
    Lemmee guess, Dunkin Donuts.....There is a rack location reed switch (N.C.) attached to the roof of the oven at 9 o'clock and a magnet attached to the pulley. Check to see if it is stuck closed. Also check and see if the bracket holding the magnet is attached. The rack will rotate until the magnet engages the switch. The inputs to the door switch assy come directly from the control board. Good luck!
    Apr 2011
    Joliet IL
    Quote Originally Posted by chrldwlf View Post
    no but close corner bakery thanks i didnt even think about that switch buy any chance do you know where i can get a service manual for this oven
    Indiana
    Quote Originally Posted by 83davem View Post
    Baxter is part of Hobart.
    www.hobartcorp.com
    Apr 2011
    Joliet IL
    Quote Originally Posted by msdmaint View Post
    www.hobartcorp.com
    thank you
