Results 1 to 13 of 32
    Nov 2000
    Coastal Georgia
    What does that mean? Just noticed my A/C was not cooling. Went outside and found frost all over that line? Is there something I can do?
    South Central Kansas
    Call NASA and advise to postpone the next liftoff!
    May 2005
    It means the copper line has reached 32 or below. low refrigerant charge,airflow problem,or restriction in refrigeration system.
    Nov 2001
    everything ok today James ?
    Which have you done ?
    Mar 2002
    Richmond, Virginia
    This is not a diy site, BUTT, I would recommend carefully chipping the ice off and using it to keep the beer cold.
    May 2005
    James I was only in long enough to be a 54550. Ever been to plattsburgh afb ?
    Nov 2000
    Coastal Georgia
    I called my brother in law that sells goodman equipment and he said to set the thermostat thing lower
    Nov 2000
    Coastal Georgia
    Nope..Southern Command bases and CentComm. Couple of times to Alaska
    May 2005
    dont do what brother in law says
    It means you left the door to your freezer open too long.
    personally I would not have went outside and looked at it......things I can't see ,cant hurt me.
    [Edited by dec on 06-27-2005 at 12:33 AM]
    Apr 2001
    san jose,ca.
    cover the line in chicken feathers
    North St Paul MN
    Might have to add some freezoone. Or replace the thermotaty thing.
    I'd rather have a bottle in front of me, than a frontal lobotomy.
