Results 1 to 13 of 18
    Oct 2007
    Huntsville, AL
    Car with rear A/C
    I have posted this question before on a automotive forum but got no replies. I was wondering if anyone knew what keeps the rear evaporator on a car from freezing when the rear blower is not on?
    Ontario Canada
    I would think that there would be a solenoid in the liquid line to prevent the flow of refrigerant when off.
    May 2010
    Probably a solenoid
    Oct 2007
    Huntsville, AL
    My 1996 Chrysler Town and Country has 2 evaporators and they both have their own fans. I was thinking the same thing as Trouble, some kind of solenoid that controls flow.
    Nov 2001
    Seattle, WA
    There is typically a low pressure sensor in series with the compressor that shuts the compressor off if the suction pressure becomes too low. That is what keeps the coil(s) from freezing most of the time. Under certain conditions they still will freeze no matter what but you won't know it except for the loss of air flow.
    The auto industry calls it a subcool switch or something like that.
    - Alexis de Toqueville, 1835
    Oct 2007
    Huntsville, AL
    Quote Originally Posted by DeltaT View Post
    So if I do not want the cooling in the rear of my van to be on then the front has to suffer because it is going to cause the compressor to shut off on low pressure?
    Nov 2001
    Seattle, WA
    No matter how the system is configured, one evap or two or three, most all auto air conditioning systems have a low pressure switch in series with the auto compressor to protect the compressor. When the coil(s) get too cold the suction pressure gets too low and the low pressure switch starts to cycle the compressor on and off.
    This is happening no matter what and most people don't even realize it.
    The other control, if you have it, is the supply air thermostat sensing the discharge temp coming out of the A/C coil box. That will also cycle the compressor on and off.
    So, as one example, if someone has the blower on low speed on one or both coils the discharge air sensor thermostat will, again, start to cycle the compressor on and off to protect the system again.
    The only real way to know about your particular car is go exploring for components and/or start experinemting with how the thermostats and controls work. It should be very easy to do by just starting one coil first and turning the fan to low to see what is cycling the compressor. It will cycle even though you may not be aware of that.
    MN
    I would think that a TXV on each coil would do the trick also.
    Oct 2007
    Huntsville, AL
    Quote Originally Posted by doc havoc View Post
    Yes, They both have a TXV. That was my original thought but I was not sure... Now that I think about it, if there was a solenoid that cut off the liquid line wouldn't the system then be overcharged for the one evaporator that is being used?
    Midwest
    Can't remember what controls it, but some vehicles have variable displacement compressors.
    Apr 2010
    East of Lyndon's
    Quote Originally Posted by CountryBumpkin View Post
    Most new vehicles have an orifice that feeds both evaps. With the orifice system, the compressor cycles off and on with the low pressure switch. If you don't run rear blower the front evap should work just fine. If you've got a TXV on each evap it should work even better but I haven't seen a TXV on a auto for quite a few years!
    If you can't fix it with a hammer, you've got an electrical problem.
    Dec 2003
    Citrus County, Florida
    the rear evaps have TXV's and a solenoid. The front evaps have orfice tubes, TXV's, Variable displacement compressors with control valves.
    Country Bumpkin, what year and model do you have? I have info for up to 2001 and can look it up for you.
    Doug
    May 2010
