06-25-2005, 04:47 PM #1
- May 2004
- 22
original thread:
http://hvac-talk.com/vbb/showthread.php?threadid=78597
I’m waiting to have my second contractor come Tuesday and repair/finish the installation that the first guy dropped the ball on.
I now notice that the furnace, an Amana AMV80905CXA has a 5 ton blower (The original discussion was to install a 4 ton - AMV80704BXA - blower). The Outside AC unit is an Amana RCE42C2A 3.5 ton.
So I am at a crossroads - should I have the new contractor simply supply the missing transition - or should I replace the 5 ton blower with a 4 ton?
Will just keeping the 5 ton pose any significant problem down the road?
Man, this is a nightmare...
06-25-2005, 05:27 PM #2
- Sep 2002
- I don't know
- 2,888
The cooling blower speed should be adjusted for proper temperature drop across the coil. 5-ton is most likely just the maximum a/c which can be installed with that furnace.
Wait for someone else to confirm this.
06-25-2005, 05:36 PM #3
Confirmed
We take a static pressure to see how restrictive the duct system is. Then set blower speeds accordingly which most likely is medium high with a 4 ton air on a 5 ton max blower.
06-25-2005, 06:32 PM #4
- May 2004
- 22
thanks guys - didn't mean to get breathless - ;-)
