Results 1 to 7 of 7
Thread: HO Question
    Atlanta, Ga. burbs
    Am I losing it?
    Situation: New heat pump/new programmable thermostat installed by licensed HVAC tech. Metro Atlanta area temp. outdoors is HOT and humid.
    Problem: Programmable thermostate is 'magically' resetting itself from 70's setting to 85 and it is going off hold.
    Environment: Two teen girls 19 years old, 1 teen boy 14 years old. They all swear they never touch it.
    Am I losing it? Can a programmable thermostat (which was never programmed) randomly and I mean randomly reset itself to another temp. and take it self off hold?
    I keep telling my wife the kids are messing with it. They deny it.
    Apr 2005
    ...strange indeed.
    What kind of programmable stat is it west_seth?
    Atlanta, Ga. burbs
    Thermostat type
    It is a White Rodgers 1F82 261 and it is for a heat pump. Installer did the install.
    I am thinking about going back to an old timey non programmable type.
    Apr 2001
    san jose,ca.
    I`ve had the same problem with the w/r if stats,not all of them ,just a few.I programed to the settings that you have when you had it on hold,so when it switched off hold it still had your settings.I really don`t know why some do that.
    Atlanta, Ga. burbs
    Mystery solved......
    I printed off the instructions off the internet and read them. Can't say I understand every little setting but you all were right. The thing can and does reset itself, in my case to factory settings, despite being on hold to 85 degrees as per factory default. So I re-programmed it to a constat temp. in the 70's thus not really using the energy saving mode.
    I've got to go hug the kids they said all along it was the thermostat. No it was dear old Dad. But I did think hold meant hold meant hold. Not sure why installer did not leave the book that came with it but it was on the website.
    Thanks all.
    Wes
    Apr 2005
    Tampa, Florida
    I'm not sure about that particular stat, but some stats have temporary & permanent holds, as 2 separate modes. If you just adjust the temperature using the up/down buttons, usually this will put a digital thermostat into a temporary hold, which usually only lasts for a few hours or until the next programmed period, then it will automatically reset back to the program temperatures. Some thermostats will only allow temporary holds, although this is usually done on commercial setups.
    So, make sure you're actually using the permanent hold instead of the temporary one... This is usually accomplished by pushing a Hold or Permanent Hold button.
    Apr 2001
    san jose,ca.
    These t-stats only have 1 hold button that sopposed to over-ride factory setting, BUT they all got a mind of their own.
