Results 1 to 9 of 9
Thread: Old Tappan/York
    I am installing a new Trane A/C and heat unit tomarrow. But my old one is a Tappan outside unit model CM-30-44-C. And the inside unit is a York 32UF16-B. I was wondering if any of you experts can tell me what tonnage these old units are. I am putting in a 2.5 ton for my small but cozy 1100sf house.
    Grottoes VA
    Have you done a load calculation on your house. 2.5ton seems a little big for 1100 Sqft. You will be cold but wet with an oversized unit. Your electric bill will be much higher also.
    You don't get eff. with short run times.
    this is what was recommended.
    Houston,Tx.
    If 2.5 tons is what you have had all along and it feels good "DO IT".
    Grottoes VA
    by whom? we can tell you the error of his ways.
    Where you located?
    Just remember that new units don't always suck the moisture out like the old relics with their low suction and thick coils. Even though 2.5 ton was fine all along, a new oversized unit may be less comfy than the old one.
    Nov 2000
    Eastern PA
    Wait a minute; you are installing a system that someone else told you what size to install?
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    The old 400 sq ft to the ton method.
    I'm with baldie, it might not remove the humidity as well.
    Get a load calc done, it could save you alot of money.
    And alot of greif.
    This was recommended by Trane. I don't know the size of my old unit. I supplied the model # in the first post. The new unit is now in place and has been running for about an hour now. I live just south of Dallas, TX. I will see what results I get and post them. Thank you for all the post.
    DEREK
