Results 1 to 12 of 12
    IVe had good luck using this sort of Thread Compound Paste on refrigerant leaks that occur due to the schreader cores' gasket leaking minutely (typically over the course of a cold winter).
    What are you guys using , if anything ?
    Jun 2001
    We prefer o-ringed caps. if your refering to service caps, i would agree.
    New York
    Nothing, Replace the core. Any crap you put on there gets in your hoses. If you dont have the proper tool to replace the core, use a cap w/ the rubber gasket in it or install a schrater tee, female flare w/ pin depresser on the bull or run, and two usable 1/4" acsess ports.
    leland nc
    i always replace the cores and install o-ring caps
    South Dakota
    I just braze em up. Never have any leakage after that.
    New York
    Angry
    Hey Norm, I think I was working on one of your machines the other day, you did a nice job filling the little hole on the 1/4" male acsses ports, my hoses went on, my gauges read 0, butmy suction line was sweating and my hot gas was hot.... I couldnt understand that LMAO...
    South Dakota
    It is a sealed system. Field Sealed!
    North St Paul MN
    Teflon tape on the threads, then after the caps are put on, black tape. After the black tape is put on, then cork tape. Then thumb gum. No leaks.
    I'd rather have a bottle in front of me, than a frontal lobotomy.
    Apr 2003
    Are you...
    ...the same BOZO that's been doing shiit like this too?
    As well as putting thread sealant on flare fittings!
    I wouldnt use teflon on the service ports, just change the core and replace cap with one that has the o ring, I do use teflon on the main body caps though. If i didnt do this and replaced the valves instead. I would be replacing so called bad service valves everyday.
    You guys are forgetting that "hvacfella" is not even in the trade... that's why he has such hare-brained ideas. And before you protest Dave, being an "HVAC owner" does not qualify as being in the trade.
    Florida
    Re: Are you...
    Nah.....If I did it you'd see the channel lock thread marks and they'd be much more rounded off after I put the gorilla grip to 'em.
