    I have a GMPN120-5 furnace and a CK49-18 air conditioning unit, installed in 1997. When cooling, the blower seems to cycle very frequently. It is on for about 2 minutes, then stays off for only about 30-45 seconds. Doesn't seem right to me??? I did not notice that it does this in heating season...only cooling.
    Houston,Tx.
    That could be a thermostat issue.
    yes sounds like you have a bad t-stat need to change it
    should have a tech come out and check it out
