Results 1 to 7 of 7
    HVAC guy still here and cannot get the air handler on zone system to shut off even when new board and the thermostats are disconnected. Any idea?
    Jul 2000
    Columbia, SC. USA
    Blower relay or blower board bad...? Is someone looking over my shoulder?!?!
    Apr 2005
    Richmond, Virginia
    Give the guy a break. It's a short between R and G.
    Disconnect R and G from unit and ohm out until you find short.
    Sean Cantrell
    Lancaster PA
    If he disconnects the green wire from the G terminal, and the fan still runs.
    Then if its a heat pump, check to see if the limit is open.
    Hell Hole Swamp
    Find a tech who knows how to troubleshoot a simple low voltage problem, or possibly a stuck contact on a relay
    Turns out there was a small black U shaped wire laying at the botton below the interior board in the unit. Some kind of relay that had fell out. He put both ends of that in and everything works works!
    Suppy NC
    if it is electric airhandler wigth heaters i think the sequencer is stuck and not turning fan off
