Results 1 to 11 of 11
Thread: superheat
    ok how do you find out what the proper superheat should be.
    senerio outside temp 86 indoor wet bulb 58 indoor dry bulb 72.
    Senior Tech Guest
    Go to the "For your interest" section. Read up on superheat and subcool and then come back with your questions.
    Houston,Texas
    What? I will save this one for Norm.
    “Experience is a hard teacher because she gives the test first, the lesson afterwards" ~ Vernon Law
    "It's what you learn after you know it all that counts." ~ John Wooden
    "When the teachers become unteachable we're all in trouble" ~ Mr. Bill
    "Remember "Pro" is only a name, it's not always a mindset determined to do everything correctly" ~ Mr. Bill
    go to...
    ...the supply house and buy a slide rule calculator...Trane makes a good one
    slide rule calc
    none of the supply houses here in great falls mt have them i have been trying to find one online but cant. Can I get one direct from trane?
    Apr 2003
    Check the equipment spec sheets... they will give you a chart for the different types of metering devices.
    Some will even go further with SP, LP, Amps, SH, SC, etc, etc...
    Hmm
    There is a guy on ebay that sells Carrier charts for like 15 bucks. I have a SH-31 and never using it.Its good for P/M work. Or as a learning tool, But you cant beat a good thermometer and a Temp Clamp. I carry a Fieldpiece thermometer and a Fluke line clamp in my tool bag fits nicey nice in bag. If you got a Fluke 16 they work well for line temps as well.
    [Edited by fitter638nyc on 06-23-2005 at 03:36 AM]
    Tin Knockers BANG for a living
    58 x 3 = 174
    174 - 80 = 94
    94 - 86 = 14
    14 / 2 = 7
    7° super heat for your senario.
    Apr 2002
    Battle Creek, MI
    Re: slide rule calc
    Yes, you can order them directly from Trane or Carrier, but there is a minimum order of $25 plus shipping & tax. It gets rather expensive for just one.
    Here's a source with a minimum order of $10, but you can meet that by buying an R-22 slide-chart and an R-410A slide-chart, plus shipping of course.
    http://www.123supply.com/clearspec.html
    If you just want a simple chart that uses indoor WB and outdoor DB then look here:
    http://www.rhvactools.com/
    and click on "A/C supherheat card"
    South Dakota
    I see you are in Great Falls. Go to the Johnstone Supply there and ask them for one. They are a Coleman supplier and Coleman has such a slide rule. I have several.
    Coleman has them for both R22 and 410A.
    Norm
    Great thanks I will get one from johnstone.
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
