Here is my take. I would tell your builder to get his but over there and get your a/c system that you paid alot of money for to work correctly! You should be able too w/ no problem get that house 15 deg or better, cooler then outside(thats at a minimum). If he wants to insulate the ducts better, install an attic fan or whatever, then let him, Attics are always going to be hot. The bottom line, whats going to happen if you have a party w/ 20 plus people and your wife wants to turn on the stove and cook something? Whats the temp going to be in there then? You dont have to answer that lol. I dont know your house ceilings etc. I did see the floor plan. I would not have installed a 2 1/2 ton in that house, some people may have, dont know why??? I would not have been back because it was undersized. You have 1733sq.ft of living space correct?
[Edited by ultratec on 06-23-2005 at 03:49 PM]
The temps I took were with the ac running for a long time.
Ultratec I believe what you are saying is on the right track!
I think the damb builder skimped on the system to save money. The ac shouldn't have to run all day to keep the temp two degree's bellow 80. I can tell you that when we cook the house does get warm.
Even at night the ac has to run a long time just to keep the house cool.
I believe I am about to get into a huge fight with the builder.
I need help on where to get some information.
Is there a standard code for Texas or national code that says what the minimum size unit in new construction should be?
Should I get the builder to do a J-calc of the house and get his results?
Should I pay to get an independent person to do a calc?
What should be the best approach to take?
BBB maybee
Originally posted by smp7015
T
This is pretty crapy having a new house that won't get bellow 80 degree's in the summer time.
A common poblem I see are ducts in attics that are exposed. Ducts are minimally insulated and can lose upwards of 20% of their cooling load. Leaks are another problem. If the duct work was done in a hack way, they could be leaking. Lack of insulation could also be a problem. Not only through heat gains through the ducts, but also through your entire house.
If you have a vented attic, fiberglass is a particularly bad insulator. If your attic is fiberglass, have some cellulose blown on top of it. Bury the exposed ducts with cellulose also.
in arizona the ROC oversees licsened contractors and responds to complaints against contractors, they make judgements about if equipment is doing what it should,,I am sure your state has similar..
What part of texas are you in? I have never delt with the home builder your talking about but it sounds like you got the misfortune of one of those companies that does everything on the cheap.
My recommendation would be to call an other company out to do a load calc with a computer. Also tell them you want them to take surface temp readings in your home to see if you have insulation issues. Best of luck to you on finding one that can and will do this and be honest.
Nobody here can tell you if you ac is the right size or not. I have homes that size with everything from 2 ton to 4 ton and possible even 1 or 2 that are 5 tons.
HVAC Contractor, Tyler Texas.
Texas builders, sigh...
I've always been told that in Texas the game is rigged against the homeowner (HO) to protect the builder against his own misdeeds. Would bet a steak dinner that when you bought your Perry home, you also signed an agreement you will never sue and will settle all problems via an arbitrator -- who is friendly with the builders. So don't place much hopes on the BBB here, you may have to get more creative.
I believe it would be wise to collect all the WRITTEN information you can, to prove objectively the AC is not doing its job. Of course YOU know it isn't cooling, but try to prove it every way you can. One way would be to hire a pro to evaluate your AC and try to identify its faults. A written report by a professional, would be strong evidence in an arbitration hearing. Worth paying for.
BTW you bought a thermometer at Walmart, did you buy the model which has humidity too? Your inside humidity would be an important clue. If it is too high and could be lowered, that might let you be comfortable without cooling "too low" (the builder will possibly claim you have unreasonable goals for temperature levels). Don't totally rule out the value of a dehumidifier to help the problem -- I have one and keep humidity around 50% even in the mild spring and fall climate when no AC temperature cooling is really needed.
But fix what you can in the existing AC system. Don't fall for the story that bigger is automatically better, you might be failing to cool because of a big duct leak or other craftsmanship issue.
You may pay more than you would like to, for professionals to figure things out, but I can see no better solution. Think of it this way... you might pay some serious bucks to do what the builder should have done in the first place, but the booby prize is to end up with a good working AC system. Not too shabby even if Perry homes is crooked here.
Best of luck -- P.Student
- You may not post replies
- You may not edit your posts
Forum Rules
