Results 1 to 8 of 8
    just had a new 2 stage var spreed and a/c put in , was reading the manual and saw different fan ramping profiles. they all seem to be the same, installer says i need a dehumidistat for them to work. in the book it seems like i shouldn t . is he trying to sell me more stuff. i already spent thousands
    Rochester, MN
    What Brand/Model of system do you have?
    if it's a Trane, just make sure the dip switches are set up, and jumper wire is used.. No other control is needed.
    it is a goodman, gmv90905dxa furnace, clq42 a/c. the guy said you get alot of product for the money. i tried moving those switches(please don t tell me i need a professional to change the settings, its only a slight change in airflow) but i don t get the 30 second pre run or the 7.5 minute reduced speed
    Rochester, MN
    I don't know anything aboug goodman, so I don't know how thier system works.
    and youl get more than you bargained for. it will only take a year or so.
    your saying im gonna have trouble with goodman, i thought it was the installer not the equipment
    Robo will come along and tell you what to set your switches to.
    Oct 2001
    Waterford Michigan
    Goodman had a programming error on some of the VS boards, call your contractor back to fix the problem.
