    New Hampshire
    Does anyone know how many btuh a standing pilot flame uses.
    I can't clock the meter because I only work with propane.
    To be specific, lets say its a vent free fireplace insert logset 35000 btu.
    An approximation would be good enough.
    S.E. Pa
    pilot burner input BTU/hr
    regular std pilots burn ~600-1,200 BTU/hr.
    However, VF pilots being ODS have special requirements which usually, depending upon mfr., results in an input of 1,200-1,600 BTU/hr.
    BTW, to clock an LP appliance, you can get a regular meter for NG and clock LP. You'll need the conversion factor from the meter mfr.. Mine requires I multiply the reading x 0.64, then complete the calculations. Also, the meter must be temperature compensating--about $120.00.
    Another way is to have the tank filled, burn for a period, refill, then do the arithmetic. Works only if this is the only appliance on the tank and it will take about a month to get an accurate reading if pilot only.
    HTH,
    New Hampshire
    Thanks.
