Results 14 to 22 of 22
    Ok. I have replaced it. There was about 56oz r22 instead of 73oz according to the label on the condenser. When I checked for leaks I found one on the pipe entering the condenser and probably that was the problem with the unit and my old compressor is not bad. Anyway I did not put it back.
    Florida
    so it was low on freon and running high suction low head pressures??? Hummmmmmmmmmmmm.
    Suppy NC
    so what was the real problem with the unit. subcool auperheat presures and line temps and td. if the old compressor is still good did you charge for the new one or just the repair
    hvac r us 2 agree on a lot of things
    Originally posted by hvac r us 2
    The question I always ask my guys is "why did it die?"
    Make no mistake a 7 year old compressor just didnt die, it was murdered!
    Dont let anybody kid you, there is a reason that compressor failed and it's not becuase it was defective, old age, a lemon, hit by lightning, voltage spiking...
    You know all the popular answers techs give when they really dont know.
    Without knowing why the first compressor failed, stands to reason the second compressor will also have the same fate.
    Ask yourself,
    How much oil is left in the old compressor?
    Is the unit mis applied?
    Long line not done correctly?This is one. Poor filter maintenance could be the culprit.
    Low ambient not done right?
    Wrong metering device?
    Bad airflow?
    How much refrigerant did you take out, was it overcharged?
    You get the idea...the answer is out there!
    smokin68
    __________________
    Is it really any easier doing it twice?????
    Hmmmmmmmmmmm is right......doesn't sound like a low charge would give you the pressure reading that you posted.
    I think there is something else to this,don't you?
    Jul 2000
    Columbia, SC. USA
    I'm So CONFUSED!!!!!!!!!!!!!!!!!!!!!
    Suppy NC
    mistake or not one thing i can say once you burn out a compressor it is history and you eat the mistake. putting it back it wont be runnig for long if at all and you just waisted two compressors
    Green oil....Hmmmm
    Copper Sulfate? Has a nice odor too....
    Dec 2003
    TXV gaged open?
