Results 1 to 13 of 15
    Hmm
    If I use carbon dioxide in the line, what would be the problem?
    South Dakota
    If you are a DIYer and you have to start out asking why you can't just use water copper as a refrigerant line then you are in for many more goofs if you procede to attempt to install your own system.
    Austin, TX
    Thumbs down
    My assumption: "Copper water tubing is not made to hold the pressures seen in AC work."
    Fact: Plumbers copper tubing is measured using the inside diameter (ID) and not the outside diameter (OD) that ACR tubing uses.
    ACR work uses dry nitrogen to pressurize the system during pressure testing to try to avoid introducing moisture into the system. The system is then vacuumed down to remove any noncondensables and water vapor.
    Fact: The materials used in ACR work are designed around certain chemical compatibilities and properties. We do the work safely by using the right materials where needed.
    Opinion: Go mucking around with it using the wrong stuff and you're setting the scene for a world of hurt. CO2 is a no-go for pressure testing in ACR work.
    “I am for doing good to the poor, but...I think the best way of doing good to the poor, is not making them easy in poverty, but leading or driving them out of it. I observed...that the more public provisions were made for the poor, the less they provided for themselves, and of course became poorer. And, on the contrary, the less was done for them, the more they did for themselves, and became richer.”
    ― Benjamin Franklin
    Nov 2000
    Eastern PA
    Refrigeration copper is manufactured cleaner and is dehydrated with sealed ends to keep it clean. There is no way to properly clean out copper that is manufactured for water usage.
    Government is a disease...
    ...masquerading as its own cure…
    Ecclesiastes 10:2 NIV
    Suppy NC
    why not just use a garden hose it is even cheaper
    Talking
    Tin: you know better than to use a garden hose for refer lines
    you save the garden hose for the gas connection
    Lancaster PA
    I wouldn't put carbon dioxide in the lines either.
    But thats just me.
    Thats absolutely rediculous ct2,
    you know it can be used for the suction side
    I've used PVC pipe for years, just be sure to use that blue cleaner on the pipe first then apply cement.
    Illinois
    Trac-pipe is a lot easier to bend.
    Hammond
    pvc? trac-pipe? you guys work too damn hard! i use 1/2 inch clear vinyl tubing and barb fittings for my refer. lines! homeowners love to see the change of state from liquid to gas!
    I don’t always drink beer, but when I do I prefer Dos-Equis. I am the most interesting man in the world. Stay thirsty my friends.
    Lancaster PA
    I came homew super depressed.
    Reading all these easier ways has really lifted my spirit.
    Thanks.
    Suppy NC
    i like to use carbon monoxcide also to clean and presure test to. i cannetect a tee in the hose and run another hose to the tail pipe of my truck. works like a charm and i save a lot of time no evactuation need and no nito either
    co displaces air real well
