Results 1 to 7 of 7
    Jun 2009
    New Haven,MO
    Coil issues,leaks
    Anyone seeing indoor air coil leakage of concern? Last year we had several air source that were thin tubing not "formocary corrosion" as we were led to believe by the manufacturer. This year had our first ones in a geo system and they were hard to detect, the die did not work.
    Jan 2011
    TN
    We have had the same issues.Not so much lately but about a year ago had a climatemaster that we put two coils in it about nine months apart.Plus we have had multiple units that we have had to replace the coil in once.Also you mentioned the leaks were hard to find amen to that.Seems like that 410 is much harder to find than 22.We use electronic detectors and nitrogen if needed.Have heard that the ultrasonic detectors work well they actually listen for the high frequency noise produced by the leak.We have talked about getting some of these but havent yet.The coils now seem to be as thin as an aluminum can.Everything is light duty throw away crap now IMHO
    Jun 2009
    New Haven,MO
    Thanks tlb I can agree with your honest opinion, I just wish the manufacurers would quit making it hard for us to do a great job!
    Apr 2011
    My Climatemaster Tranquility 27 has three separate coils inside the coil unit. The top and bottom coils are working but the missle one is not. Them seem to be connected to the same source of refregant.
    Apr 2011
    My new Climatemaster Tranquility 27 has three separate coils inside the coil unit. The top and bottom coils are working but the middle one is not. They seem to be connected to the same source of refrigerant. CM says it is a charge problem but I can’t see why a charge problem wouldn’t affect all coils. Any thoughts?
    Jun 2009
    New Haven,MO
    Usually they all are connected, that is what makes so challenging to fix. By the time you have a tech do everything to make the repair you could almost replace the whole unit, in some cases. Thanks for the comment, keep me informed.
    Jun 2009
    New Haven,MO
    I have heard of some using accumulators to help with charge issues.
