Results 1 to 4 of 4
Thread: torpedo return
06-15-2005, 12:57 AM #1
- Apr 2005
- illinois
- 257
A contractor said he would install a torpedo return for my return drop. I think this is also called a radiused return. He said it would allow my spaceguard filter to use more of it's surface area. Is there any value to have a return that curves into the air filter. Does it make the filter work better or decrease the static or is it mostly cosmetic?I have seen a return like this on some of the installs that are on the wall of pride.
[Edited by heetseeker on 06-15-2005 at 08:01 AM]
06-19-2005, 10:09 AM #2
- Jun 2005
- 64
it should curve into your filter for better operation but you will see no difference in performance . should cost less then $50 in parts and take 10 minutes to fix. honestly not that big of a deal
06-19-2005, 12:39 PM #3
Radiused els are less restrictive, give better air flow.
coco:
No pricing allowed.
06-20-2005, 03:52 PM #4
Banned
- Aug 2002
- Office and warehouse in both Crystal River & New Port Richey ,FL
- 18,836
Radiused els ,need bothe the inside and outside to have a radius,to be benificial.The inside turn is often too small,or not there at all,in which case it does littel good.
Properly done they will be less resistance(static) than a square elbow,and can improve airflow.
