Thread: torpedo return
    Apr 2005
    illinois
    A contractor said he would install a torpedo return for my return drop. I think this is also called a radiused return. He said it would allow my spaceguard filter to use more of it's surface area. Is there any value to have a return that curves into the air filter. Does it make the filter work better or decrease the static or is it mostly cosmetic?I have seen a return like this on some of the installs that are on the wall of pride.
    [Edited by heetseeker on 06-15-2005 at 08:01 AM]
    it should curve into your filter for better operation but you will see no difference in performance . should cost less then $50 in parts and take 10 minutes to fix. honestly not that big of a deal
    Radiused els are less restrictive, give better air flow.
    coco:
    No pricing allowed.
    Radiused els ,need bothe the inside and outside to have a radius,to be benificial.The inside turn is often too small,or not there at all,in which case it does littel good.
    Properly done they will be less resistance(static) than a square elbow,and can improve airflow.
