Results 1 to 13 of 21
    Jun 2005
    Unhappy Drain Line Issue - Updated w/ PICS
    The setup:
    Air-handler in attic
    Drain line leaking somewhere in between 2nd and 1st floor.
    My thought:
    Run new drain line.
    The problem: I ran 20 ft of 3/4 PVC to the opposite end of the attic because it had easy access to drill in to the wall and add a drain outlet. The PVC is at an angle and the drain outlet is 8-12 inches below the handler line.
    After the first day there was water in the opening after the p-trap and if I went to the outside drain and did a quick syphon the water flowed out.
    Since the water was coming out the presumable breathing hole I added a temp plug but is this the best thing to do or should I do something different?
    Help please......
    Jun 2005
    Update - Photo 1
    Here is what I have. The line from the unit does not look like a regular p-trap. This morning I removed the trap cleaner plug and a bunch of water flowed out. It also appeared that water leaked around the plug overnight and cause some water rings on the ceiling drywall.
    [Edited by gman69_1999 on 06-15-2005 at 03:00 PM]
    Jun 2005
    Update - Photo 2
    Here is another view:
    [Edited by gman69_1999 on 06-15-2005 at 03:01 PM]
    Jun 2005
    Update - Photo 3
    And here you can see the main drain line crossing the overflow pan line. Notice it (main drain line) is on a decent drain angle.
    Jun 2005
    Update - Photo 4
    And here is the outside view of where it drains:
    [Edited by gman69_1999 on 06-15-2005 at 03:02 PM]
    Jun 2005
    What I did today
    So this morning I went ahead an put a bead of silicon around the trap cleaner plug as I suspect that the water is leaking from there. What I am more concerned about is the fact that the water is at that plug point as it was not prior to me running the new line.
    If it doesn't leak in the next 24 hours, I will feel better but not knowing what is happening with the water in the PVC will be on my mind all the time.
    Any ideas or suggestions?
    Jul 2002
    Zelienople, Pa
    Post some pics that work...
    Jun 2005
    ??? - Pic's are displaying here
    I can see the pics just fine??..??I went ahead and moved the images to a different domain to see if that helps.
    Jun 2005
    Should work now
    Images should be ok now
    Jul 2001
    You installed the trap backwards.
    Jul 2001
    Sorry.I didn't look at the picture correctly. My mistake. How did the trap get scorched and distorted? Is the trap restricted? Could be it can't drain fast enough because of the distortion.
    Jun 2005
    That is what the AC service company did 2 years ago when they put the new unit in. It looks like they made their own trap.
    Beyond this, prior to me running the new PVC line, the trap cleaner (or open top of the T) did not have water setting in the opening or spilling out for that matter. Is it possible with the length of the new run that I need a real trap all together or can I do without?
    Atlanta, Ga. burbs
    This is your answer to your question
    I had a problem with my drain line. Installer flat out did it wrong and I could not get him back out. Someone here pointed me this site at Trane.
    http://www.trane.com/commercial/issues/iaq/iaq5.asp
    I agree the line looks constricted. Maybe they tried to make the trap by heating the plastic pipe. You can make one from elbows very easily. See the link and good luck.
