If the outdoor unit is a single stage, and you didn't get a humidistat installed, it will run on high speed any time the stat calls for cooling.
If you have the humidistat installed, any time the humidity is above set point, and the a/c is running, the blower will only go to 83% till the humidity is down, or the stat is satisfied.
