Results 1 to 2 of 2
Thread: TXV
    I have a 13 SEER System W/410A refrigirant.
    Temp. diff. between ceiling reg. and return air is only 10 degrees.
    How can I determine if the TXV is working properly?
    The TXV bulb is placed outside the airhandler case with tape insulation.
    Maine
    As for the TXV you can't. You will need to call a pro. Temps for the supply side should be taken near the evap, poorly insulated ducts in hot attics will give you a false temp.
