    I have a GE condenser unit Model # BTB924A100A1 Can you tell me how many tons this is.Thanks in advance
    Nov 2002
    VA
    Trane Eagle CD's
    jenn9637210;
    My initial "guess" would be a capacity of 2-Tons base on the "24" imbedded in your unit's Model Number BTB924A100A1.
    There are 12,000BTU's in One Ton of cooling capacity. Note that BTU's (British Thermal Units) are a per hour value, and Ton's are a per day value. The Ton value comes from an era when cooling was acomplished with ice, thus One Ton of Ice melting over a delta time increment of 24-hours absorbs (12,000 x 24) 288,000BTU's.
    To be absolutely certain you need to touch base with someone who has a copy of Trane's Eagle CD's which contain the aggregate data for all GE's models.
    Hope this helps...
    It certainly does........Thank You
    Nov 2003
    South Carolina
    there arent many of them old ge's left. Better think about replacement pretty soon or your gonna get hit on the worst day possible.
