Originally Posted by
88ducksinarow
Hi,
We would like to replace hot-water radiators with hydronic air handlers. And we are wondering if it's possible to use existing hot-water boiler?
If you have cast iron radiators, you should speak with a hydronics expert in your area before committing to hydro-air. Most folks would readily give up their hydro-air installations to have real cast iron radiators.
If on the other hand you're mislabelling the distribution system and calling finnded copper baseboard radiators, then that's a different story.
Yes your boiler can be used to run a hydro-air system but, since you don't state your reasons for the switch it's just a guessing game for us out her on the cloud.
Castl iron is a radiant panel by any other name. It can produce heat at very low water temperatures and ideally would be driven by a modulating/condensing gas boiler (if gas is the fuel) that will regulate the heating water temperatures up/down according to the outdoor temps. That can and should lead to constant heat throughout most of the winter. It's very difficult to re-produce that with other forms of hydronic heat, except for radiant floors, walls or ceilings.
