Results 1 to 9 of 9
    Mar 2009
    Carrier premier link question
    I am in need of converting a carrier RTU with factory installed premier link to T stat control.
    The unit is part of a ccn.
    Will I need to incorporate any CTI boards into the price or will a t-stat wire in without any extra boards.
    Also if no boards are needed, what is the procedure for t-stat wiring?
    Thanks.
    steeler nation
    do you still need the rtu on the network? if not you can just use a conventional thermostat.
    if you want the rtu on the network you need to use a system pilot as the thermostat
    IV IV IX
    use your head for something other than a hat rack.......Gerry
    We have freedom because somebody fought for it.
    We keep it because we are willing to fight for it.
    We lose it because we are not willing to fight for it.
    Mar 2009
    Thanks. It will no longer be on network.
    East of big city prices.
    Just curious as to why you wouldn`t want this unit on the CCN with other unit`s I pressume.
    Mar 2009
    The customer's BMS does not comunicate with CCN. It is being retrofitted to the customers system. The CCN will be removed and the comm wire utilized.
    Melbourne,Aus
    To what system...can I ask?????
    Quote Originally Posted by cold spell View Post
    Dec 2006
    Washington, DC
    No need to remove the PremierLink. It will work with a conventional thermostat. It just needs to be configured, the discrete inputs [G/Y1/Y2/W1/W2/ENTH] are on the lower left of the control board.
    Quote Originally Posted by Qui-Gon Jinn (Star Wars Episode 1)
    "The ablilty to speak does not make you intelligent!"
    Mar 2009
    Quote Originally Posted by Balibe View Post
    Thank you
    Quote Originally Posted by Ausccn
    The BMS is Comtrol. It used to comunicate, however the 4500 board got wet due to roof leak. I am told that these 4500's are no longer available.
    I'm open to any and all advice.
    Thanks.
    Aug 2009
    Exactly what he said !!!
