Results 1 to 7 of 7
    Apr 2005
    Virginia
    I have a question on charging a Payne 1.5 ton H.P. with a fixed metering devise with superheat. I followed the charging procedure according to manufactures specs. which are find the wet bulb temp of the air entering evaporator coil which was 72 deg. and outdoor temp which was 85 deg. According to the first chart is stated that I had a superheat temp of 26. So I went on to the second chart provided by manufacture which stated at 26 deg. superheat and the suction pressure of 73 psi the suction line temp should be 61 deg. which i achieved by removing a little freon. Does this sound right. Because I have read many times on this site that the superheat should be between 10-20. Indoor temp was 84 and I ended up with a delta t of 16 deg. What doesn,t make since to me is the superheat chart went from 0 to 40 deg superheat.
    The superheat should be what the mfr says. Hot in cool out you'll have a 30-40 degree superheat. Cool in hot out you'll have almost no superheat. The joys of a piston. Superheat is based on inside load and outdoor temp.
    Fort Worth, TX
    Bald One is right on. The 10-20 degree superheat you referred to is for TXV systems.
    Hot ambient outdoors and cool temps across coil indoors will result in low superheat with a piston due to both reduced heat load and increased mass flow rate through evap due to higher head pressure from higher outdoor ambient.
    Have I mentioned that I think pistons are crap?
    Building Physics Rule #2:
    Building Physics Rule #3:
    Sep 2003
    72° wetbulb indside? Did you perhaps measure dry bulb?
    Sep 2001
    Vancouver Canada
    sadlier
    He mentioned 72 degrees wetbulb, 84 degrees dry bulb indoor temp.
    "Go big or Go Home"
    Illinois
    Hmm
    Your #'s don't add up. You said you have a 84degF indoor drybulb and a 85deg outdoor drybulb and a 16deg delta T. I'm confused!Are you sure these are the right #'s?
    Apr 2005
    Virginia
    I am pretty sure my numbers are correct, I will have have to back over service report. And why don't the numbers add up? I will post the results again when I have the report in front of me. I wish my memory was alot better I have that CRS disease( Can't Remember SH**) Its terrible I know!
