Results 1 to 13 of 33
    Mar 2011
    19 seer resi new const
    Job from a few years ago , wasnt quite finished at time of photo.
    Other than the little unit blowing into the big unit, looks good.
    Mar 2011
    Thank you Mr. Loonie , no kidding , if I remember right we werent too happy about the size of the slab for cond. units.
    Dry as a bone Tucson
    Ground hog day, echoooooooo, double posts
    What BaldLoonie meant was that your CU air is getting deflected because of the "looks great" but useless plastic diverter on the top.
    You obviously take the time and make the effort to do things well.
    Some suggestions for the future:
    1. Use cush clamps and strut on your linesets.
    2. Bring your pipe out and away from the evap coil for service access in the future. It is code in some areas.
    3. You should trap that condensate. Those hi velocity filters will more than likely be replaced with pleateds and then the condensate wont drain properly.
    4. Tight area , remember that 30" should be considered the minimum for service access.
    John Proctor
    Watchman Nee
    Mar 2011
    Quote Originally Posted by ACFIXR View Post
    Thank you for the reply , 1 - job was not finished at time of photo , clamps and strut came soon after. 2- Ya thats true , however you can still get that coil access panel off , any major cleaning and the coil will have to be pulled anyway. 3 - The condensate lines are in the slab and rise outside , they are trapped. This house has ducted returns with multiple grills for low pressure drop with pleats. 4 - For sure! Sometimes the builders dont give you what you need. Although I wouldnt do the job if their requirements were TOO objectionable.
    The very humid south
    Looks great!
    Mar 2011
    Quote Originally Posted by acsolutionsllc View Post
    Looks great!
    Thanks a million! Appreciate that comment.
    Jan 2011
    Proper air filters? Not a fan of duct board at all.
    Feb 2011
    Anyone else feel those condensers are a little close to each other and the corner/ wall? More than just from a service access perspective, from a functionality perspective
    Mar 2011
    Quote Originally Posted by Hheating View Post
    Dude the condensing units are fine! SHEESH. They are 19 seer people. Way oversized coil. Even with a 90* start up they ran a 100* condensing temperature. A 10* TD. Pretty darn good. 12* Subcooling. Are we in the real world here? Or just quoting installation manual specs.
    Mar 2011
    Believe me , if I woulda had more room.... If its a big slab ill space them out as wide as I can. But they still ran fine. We turned down a job once on that note.... the builder wanted us to install multiple c/u's under a stairwell , big time cond air recirc. We didnt bid on it. Also , in FL you always have a good breeze. Think about it.
    Mar 2011
    Quote Originally Posted by jimmyed View Post
    Really? C'mon.
    Jan 2011
    Quote Originally Posted by AiResearch View Post
    Really? C'mon.
    Yeah, been 4 or 5 years since we have used duct board..
