Page 1 of 5 12345 LastLast
Results 1 to 13 of 57
    Mar 2011
    East Coast FL
    Florida light commercial installation
    Basic 7.5 ton , 2 stage cooling , dual circuit. Anyone like?Click image for larger version.
    Cincinnati, Oh
    theres no way 7 tons is gonna go through that transistion correctly.
    "Just get it done son."
    Dad adjusted
    Mar 2011
    East Coast FL
    The duct system was short , thru wall and turn with trunkline and sidewalls for open room , it was sized for a .1 static and the airflow was quite good without being noisy , actually. That air handler will do much pressure that that. What can I say it was a budget job but we always put craftsmanship in.
    Indiana
    why not sheet metal? budget job is no excuse..If you are just he installer then I know you dont make those decisions. but if you are the one making them then why not quote for proper duct work? Using quack board in commercial application is not acceptable to me.
    "its up to code" is not an acceptable answer
    Does the condensation and refrigerant lines run threw the R/A??
    Mar 2011
    East Coast FL
    Well , at the time , we were hungry (family business) and a job taken with less profit is better than sitting at the shop sweeping the floor. Duct board , when applied and constructed properly , is a fine material , it has very good acoustic qualities , can be fabricated at the jobsite , is highly resistant to condensation on the exterior , and in my experience , with the new boards , very little glass fibers make their way out the grills. When static pressure and velocity are kept moderate , duct board is fine. Also , air conditioning materials used on jobs are highly regional. Condensate and refrigerant lines were in the R/A , they were also isolated with a simple metal chase. Thank you for the comments.
    Jul 2009
    In a mechanical room....
    Quote Originally Posted by yellowirenut View Post
    why not sheet metal? budget job is no excuse..If you are just he installer then I know you don't make those decisions. but if you are the one making them then why not quote for proper duct work? Using quack board in commercial application is not acceptable to me.
    I know allot of you guys are sheet metal only guy however in Florida especially south Florida metal unfortunately dose not exist as it dose in the rest of the country.
    They do some spiral round work out here and some pre fabed stuff but the shops down here aren't even equipped to work on sheet metal.
    We just do not use metal down here like the rest of the country. They even use fiberglass turning vanes in the fiberglass duct work.
    “It takes courage to grow up and turn out to be who you really are.”
    - E.E. Cummings
    Mar 2011
    East Coast FL
    chrishvacman - you know , your right. Having been born and raised in east central FL , I can tell you that metal is mostly used in large commercial (hospitals , schools , office buildings) and industrial. Resi and retail is ductboard and flex. People also need to remember that FL has extremely high humidity and everything seems to sweat. So fiberglass duct makes sense. Money probly has a lot to do with it as well.
    Oct 2007
    Milwaukee,WI
    I hope theres vanes in that elbow. Doesn't look like it from here.
    Doesn't look like the duct is mechanically fastened to the unit either.... just taped.
    ___________________________
    Chicago is an indian word for stinky!!!!!!
    -supertek65
    Mar 2011
    East Coast FL
    No vanes on that one. You guys are tough crowd !! The airflow was smooth and nice being that it was a short duct system with low pressure.
    Mar 2011
    East Coast FL
    Maybe if I submit another wall of pride someday it will be more up to par for this section.
    Indiana
    Quote Originally Posted by AiResearch View Post
    Sorry did not mean to bash you personally...was being gumpy.
    Mar 2011
    East Coast FL
    Next time use a red wire nut!!! No problem , if you cant take a critique , then dont post on wall of pride rite.
    Mar 2010
    personall i don't use ductboard but to each his own looks clean. the only thing i don't get is the sightglasses on the inside.
