    If my contractor does a piston swap (from 59 to 57) and then vacuums system to 500 microns does he also need to change filter dryer??
    week old system
    Feb 2005
    Alabama
    Anytime the system is open up, a new dryer should be installed just in case.
    "If you can't fix it, don't break it."
    dang mike you have threads all over the place, anyway if you have a PROBLEM system CHANGE THE FILTER DRIER no way I would leave one in a system that was having problems, even if it was only a day old. What is the latest, did you get the new orfice in? I never saw any pressures posted for your unit do you have those avaliable?
    Have the kink fixed at the same time.
    leland nc
    why change the piston. if he is going though the trouble to install a new pistonor orfice then i sugest you step up and pay him to install a txv and be done with it once and for all. i personaly feel the scrol compressor works better with an expansion valve then an orfice
    it will cost a little more and will work a lot better
    my opinoun only
