Results 1 to 13 of 36
    What is the main cause of death for ac dual caps, or caps in general?
    Found three blistered yesterday, systems in spec
    Apr 2005
    NE PA
    Capacitors deteroriate over time. There are 3 general factors in order of significance:
    1. Age
    2. Temperature
    3. Overvoltage
    Any of these factors will accelerate failure. Most failures are a result of the dielectric material (an insulator) in the cap starting to leak some current. This results in internal heating, and either a short circuit in the cap will occur, or the current conduction and heat can sometimes burn out a conduction path in the capacitor, so it becomes an open circuit (no capacitance) or occasionally the excess internal heat causes it to vent (most have a built in vent device) or in a worst case explode.
    paul
    thanks tec, i figured age was the culprit on these but thought id ask the question anyway
    Huntsville,AL
    voltage spikes
    Hell Hole Swamp
    Mexico
    Ive cut a few of the swollen ones open, many of them the dielectric fluid had hardened up and caused the cap to overheat and swell, GE caps suck...period
    Nov 2001
    Seattle, WA
    Two words for me...Mexico and China.
    - Alexis de Toqueville, 1835
    Jun 2001
    And York capacitors in Lennox HS29's. Go figure.
    Most times I find a bad run cap, the condensor coil is dirty. Heat kills them, plugged up condensor coil causes the unit to run hotter, and the higeher amperage also causes the run cap to generate more heat internally.
    All these run caps coming in units these days are very small, wich gives them less surface area to reject heat from, and less mass to heat up during the on cycles, so they run hotter. Toss in any condition that gives them less than ideal ability to cool off and *POP* goes the top.
    I find the run caps with the plastic housings to be the most reliable by far as a replacement cap.
    Some units with scroll compressors are using 60 and 80 µf run caps that are very small. I like to replace them with two 30µf or two 40µf run caps in parallel.
    This splits the heat generation between 2 caps, each of wich is usually physically larger than the origonal, giving much more reliable operation.
    I replace far more run capacitors every year than I replace any other single type of part.
    Jan 2005
    That was my call today. HO called and said AC not working. Run cap looked like it was ready to pop. What run caps do you guys carry in your trucks?
    GE of course....
    Planned part replacements...
    AllTemp Heating & Cooling
    Mar 2002
    Concord, CA
    One 4, four 5's, two of everything from 7.5 through 60, one 80 and two rather expensive but handy universals. I HATE running to the wholesaler for parts that cost nothing.
    North St Paul MN
    [i] I like to replace them with two 30µf or two 40µf run caps in parallel.[/B]
    Don't you mean in series, or have I been doing in wrong.
    I'd rather have a bottle in front of me, than a frontal lobotomy.
    Jul 2001
    Anderson,SC
    You been doing in wrong. Caps in parallel add. NATE question # 56.
    STUD
