    May 2010
    TO, Canada
    Thread reply problems.
    The problem is when I click on the thread, replyes go in order from newer to the latest ones. Sometimes when I click on the thread I have to go all the way back to see the beginning of authors post. Any suggestions? Btw it happens when I logged in as the member, but not as the guest.
    Oct 2007
    Milwaukee, WI
    Go to User CP, then to Options, then to Thread Display Mode, from there you can pick what order you want the thread displayed in.
    Steamfitters Local 601
    it's not a software problem, it's a operator error
    Quote Originally Posted by rupa104 View Post
    I checked your account. Your Thread Display Mode is set correctly to see the first post then the second post then the third and so on in order. The last post on any thread should be seen at the bottom so you may have some scrolling to do.
    If it is reversed after you have been logged on the site for a while then log off, and log back on using the "remember me" box. This should fix it.
