Results 1 to 10 of 10
    Hello, thank you for joining HVAC-Talk! We have a lot of HVAC Pros here
    who can help you make decisions and give advice about a broad range of
    comfort problems. We do have a policy, which we find works well, that
    stops us from giving explicit instructions on do it yourself repairs or
    installations. I respectfully ask that you respect this policy. Please do
    not be offended, the site is free and can not be everything to all
    members. You can read the complete set of rules here:
    http://hvac-talk.com/vbb/showthread.php?threadid=1241
    Thank you
    BC-1
    HVAC-Talk Moderator
    [Edited by BC1 on 06-08-2005 at 03:31 PM]
    Feb 2005
    Alabama
    Need more info. what size system, is it a heat pump or straight cool, what were the temps inside and out, model # on units. There are many possibilities that could cause this, air however is not one of them.
    "If you can't fix it, don't break it."
    Talking
    the high side was reading 150 (normal)and low side Retard.
    looking for the retard side of that gauge. How Retarded is the low side of your system
    Feb 2005
    Alabama
    ct2, that would be above 120 psi on the low side (vapor) of an R22 system.
    May 2003
    Dixie
    rickm have you made the call yet?
    The model number is 38CK(M),Split-System Air Conditioner. This is a stright coolant system. The size is 22-1/2".
    S.W. PA
    Isn’t there a BIG fine for hooking up gauges if you are not certified to do so?
    Also I thought rules said no D.I.Y.?
    chicago suburbs
    just keep adding refrigerant until the jug is empty.
    FILL OUT YOUR PROFILE!!
    Confused
    Sorry, I had not plan to fix the problem my self. I asked the question only to have a better understanding of what's involved when I speak to a service representative! I wasn't looking for service,or even to pin point the problem so that I could do-it-myself. I don't consider myself an expert and would leave that to individuals that are certified.
    Feb 2005
    Alabama
    The word ASSUME quickly comes to mind here, along with it's spelling. Not meant at you either rick.
