    Mar 2011
    Southern California
    Fan Coil Thermostat Wiring
    Hey Guys,
    Trying to figure out the easiest way to explain how wiring will differ between conventional/heat pump thermostats and fan coil thermostats.
    With manufacturers all using different wire color methods- how does one identify the 3 extra fan speed wires that clearly differentiate this type of thermostat from the others?
    Apr 2010
    southern california
    Give a little more info, like make and model of fan coil and thermostat in question.
    what happens when all the wires are the same color?
    Feb 2011
    OH
    what speeds on the stat are you shure .please give m# mybe you mean letter s conv. stat 5 wire with com hp 6or 7 please supply more info colors .are basic in the industry most of the time except when one breaks and when some ome uses what ather is on the truck ; also depending how many stages .
