If you have 36,000 coil and the are slab type coils then have installer's 16x28 secondary pan under the coil with Beckett ceiling saver switch.
If they are 'A' coil type then you will need 19x24" secondary drain pan with beckett safety switch inside secondary outlet of coil.This will cut voltage to condenser if overflow drain is filling,thus no more water.
