    Hello,
    I had an Infinity system installed about 8 months ago. Right now I'm getting some "suspect" humidity readings on the stat. It is showing 60%RH while my Radio Shack model (not the cheapest one) in close proximity to the Infinity control is showing 47%.
    I know there is some +or- in these things, but a 13% variance seems high to me. Honestly the humidity in the house "feels" a lot closer to 47% than it does 60%.
    FYI, the temperature readings between the two devices seem to be fairly close.
    Should I get the stat checked out???
    Thanks!
    Cash
    Lancaster PA
    I would.
    They may not have sealed the hole in the wall that the wire comes throough.
    Apr 2005
    Kingston Ontario Canada
    Originally posted by beenthere
    I would.
    Is it that important that the hole in the wall be sealed, because mine is not.
    Thorton
    Apr 2005
    Tampa, Florida
    VERY important that the wall be sealed, otherwise air from the attic/crawlspace/etc will move past the stat & it'll sense that rather than the actual inside of the house.
    Lancaster PA
    Yep, thats it.
