    Feb 2005
    Question
    When building decks around outside A/C units what is the recommended clearence around the unit and deck? I have be told 6-8in all the way to 3ft for breathability of the unit
    Nov 2003
    warren,mi.
    Why not just move the condensing unit and allow plenty of room to service it.
    Nov 2000
    Coastal Georgia
    Move the condensing unit
    Feb 2005
    Condo Cant move it
    Nov 2000
    Coastal Georgia
    I would want 3 feet as a minimum. Think ahead about a different style unit being there one day and actually servicing it.
    or go ahead and build the deck with 6 inches of clearance so that it will have to be dismantled every time it needs service
    The outside A/C unit needs a great deal of air to circulate through it to work properly--Block the airflow and you shorten the life of the unit . build the deck to close for someone to be able to work comfortably and you may not find anyone to service it.
    and dont build the deck around it - or with custom removable panels to hide it either- it needs the airflow--like everyone has tried to tellyou ---move it if you dont like it's location
