Results 1 to 2 of 2
Thread: VAV K-Factor
    Jan 2011
    VAV K-Factor
    Is there an equation between K-Factor and Velocity Pressure, or it varies with different VAV Manufactures?
    I'm not sure what exactly you are looking for, but K-factor is something that usually refers to the correction for free area of diffusers and registers.
    Velocity pressure is a value resulting from the relationship between total pressure and static pressure that is used in calculations when you are determining airflow volume.
    What are you working on?
    The key to happiness is lower expectations.
    Don't pick the fly crap out of the pepper.
