Results 1 to 13 of 20
Thread: wire size
03-09-2011, 09:36 PM #1
New Guest
- Mar 2011
- 3
wire size
Nordyne Package P5RD-036k w/ 10kW heat strip MCA 52 amps MOP 60 amps recommended wire size #8 shouldn't it be #6
03-09-2011, 09:38 PM #2
Professional Member*
- Dec 2002
- SouthEast NC ICW & Piedmont Foothills
- 7,211
who recommends # 8
it'll work, not necessarily the preferred wire size
i believed in pulling to the max, fuse to the minimum.....
03-09-2011, 09:41 PM #3
New Guest
- Mar 2011
- 3
OEM install guide
03-09-2011, 09:53 PM #4
- Dec 2003
- Citrus County, Florida
- 1,231
do a google search for ampacity. You can pull 55 amps with #8
Doug
03-09-2011, 09:59 PM #5
- Apr 2009
- Pan Handle, Fl
- 597
60 Amp requires #6
Breaker size is suppose to match wire amp rating. 60 amp breaker requires #6 wire.
Insanity: Doing the same thing over and over again expecting a different outcome!
03-09-2011, 10:00 PM #6
- May 2010
- 1,289
Use #6. You can always go bigger but not smaller. Go too big and the lug won't accept the wire size. With a 60amp breaker you should never go smaller than a #6 EVER!
03-10-2011, 11:23 AM #7
- Mar 2011
- Jamestown,SC
- 45
I would go with a 6. If you ever added 5 kw you would still be safe. A heavier wire will also make it easier to sleep at night.....
03-10-2011, 08:31 PM #8
- May 2009
- 520
It really depends on the quality of the wire (amount of insulation it has around it)
03-10-2011, 08:40 PM #9
Master Electrician here, # 6 SEC or THHN, number 6 NM is only rated for 55 amps.
03-11-2011, 10:46 AM #10
- Jul 2008
- 550
That is only if both the terminals on the breaker and equipment are 90C rated.
#8 AWG is OK if all the requirements are met (assuming 52A load/min circ rating). The terminals need to be 90C rated and the wire must be 90C rated. For copper wire it needs to be something like THHN, THHW, THW-2, THWN-2, etc as per table 310.16 in the NEC. Also make sure none of the run is exposed on a rooftop.
03-11-2011, 11:06 AM #11
- Nov 2008
- SW Florida
- 20
03-11-2011, 11:51 AM #12
03-11-2011, 02:35 PM #13
- Jul 2008
- 550
