Results 1 to 9 of 9
    Post
    Can anyone tell me if there is a general rule for units when the outside temp is X degrees, the unit should be able to cool down to Z degrees?
    I think my unit may be dying... the outside temp is about 88F and the unit is barely keeping the house down to 75F (thermo is at 72, so I like it cool.)
    Some may differ but something like 18 to 22* difference.
    But there a lot of variables involved
    Sep 2003
    That is the main purpose in calculating heat gain in the heat load calculations - to determine what size of unit is required to maintain a given temperature differential between indoors and outdoors. Some areas are OK with 10 and others prefer over 25. It depends on the area you live in.
    I live in South Louisiana. Gets pretty hot down here during the summer.
    The unit I have is original to the house which is about 20 years old. I know the efficiency must have dropped off some, but other than this temp difference issue, she is working OK.
    Sep 2003
    What's your city or what is the closest large city?
    NewOrleans
    Sep 2003
    The ACCA recommended value is 75 indoor @ 92 outdoor = 17 TD.
    Have you changed the filter? how often have you been changing it and how dirty are they when you change them
    I have an electrostatic filter that I clean usually once a month. Sometimes its dirty and sometimes just a little.
    The filter is a little old... time for a new one maybe?
