Page 1 of 4 1234 LastLast
Results 1 to 13 of 45
    Apr 2005
    illinois
    I asked my contractor if he pulls a vacuum after he charges the system and asked about using a micron gauge which I learned about on this site. He says he uses a U tube manometer which accomplishes the same thing. Is he correct?
    yea , the little bitty marks on that U-tube measure microns
    Actually I remember those days,micron guages haven't always been around,we didn't all grow up in a electronics/digital age.
    U-tube filled with Mercury,was used before digital,read in inches of mercury,not microns.
    Is this guy as old as me?
    I remember getting one for refrigation work,way back in the late 60's,had it mounted to a huge belt driven vacuum pump.
    I surprised any one would still be using one today,sure he's not pulling your leg?
    SW FL
    Correct is ALL Relative !
    If his age = 74 +, he is correct.
    Designer Dan
    Apr 2005
    illinois
    No he wasn't kidding. He seems to be in his mid fifties.
    Maybe that is also why he said he never heard of using nitrogen with brazing with 30 years in the industry. He uses 15% silver solder for brazing but no nitrogen. How important is the nitrogen since I have read on this site that you still get ash with the nitrogen?
    A U tube manometer couldn't possibly have the resolution at low microns that a micron gauge has. It would be only slightly more accurate than a compound gauge....
    Apr 2005
    illinois
    Do you have to pull a vacuum to more than a certain level or just to a certain level. Is the precision a signicant factor?
    You won't get any ash with if you braze with nitrogen flowing through the pipe while you braze.
    I find it hard to believe anybody still uses a u tube for vacuum. But its possible.
    You should have asked him to see it, its a museum piece.
    Not true Yellow Jacket still sells them I have one, manufactured by The Scot & Fetzer Company, never used it. Bought it from that surplus equiment place on the internet... In Indiana near John...
    Wish it were a musuem piece I'd sell it,lol
    AllTemp Heating & Cooling
    Ain't seen one since the 70's.
    Thanks for the update.
    Why did you buy it.
    Because I could...
    Why did you buy it.
    Just looked interesting saw it in their catalog and it was cheap....
    Jul 2001
    Gold Coast of Connecticut
    heetseeker
    Member
    I would not get over excited or worried, i almost never use a micron gauge and have never used nitrogen to braze a few lines on a residential cooling unit. I pride myself on quality work and I have never ever had a problem with a small system due to not using nitrogen or a micron gauge unless it was a severe burnout or sucked in moisture.
    Relax and let the man install you new system.
    Aire Serv of SW Connecticut- Gas heat, dual fuel and central a/c systems installed and serviced
    Apr 2005
    illinois
    freeze
    Why do you say you have not had a problem with a "small"
    system. I will have a 4 ton and a 1.5 ton a/c placed. Are you talking small in relation to commercial jobs? How do you get rid of moisture in the system without a micron gauge?
