Results 1 to 13 of 19
Thread: ghost fan..??
    May 2005
    a friend of mine says her fan comes on all by its self..
    the t-stat is one of those old round non-digital ones.
    its set on auto, and the heat/cooling is in off.
    but insists the fan comes on all by its self then shuts off..
    can someone give me a clue?
    how would you like the thermostat to work.? if it wont turn off then set the temp do that it will
    Lancaster PA
    Where is the unit located.
    Some attics get hot enough for the fan/limit switch to start the fan, and then shut it off when the sensor cools.
    May 2005
    ct, the way the t-stat is set, fan on auto and cooling/heat on off, why would the fan come on??
    been, it hasnt got hot enough here..the heater is in the garage..the ac unit is on the south wall..
    Senior Tech Guest
    Bet it's a comfortmaker furnace...any takers?
    Glendale AZ
    You may need a resistor between G and C to stop the ghost fan.
    The bitterness of poor quality remains long after the sweetness of low price has gone.
    May 2005
    what size??
    Lancaster PA
    Brand, and mod of furnace?
    Aug 2001
    does the furnace have a camstat
    With that little of information.....who knows? Now as much as I made answering that question......the answer was worth about the same.
    May 2005
    "i'll be bock"...
    Primmers.......Im just curious, Now at first I thought you were a homeowner trying to fix a friends furnace. Now I see that you are a tech, from looking at your other posts. Am I right?
    Lancaster PA
    looks like he's a refer guy.
