    Chicago
    Is there any way of putting oil in an R22 system without drawing a vacuum on it?
    Also, If I have to draw a vacuum on it, what pressure should I draw the suction line to before I lock off the service valves.
    you really insist on destroying your unit this weekend , dont you?
    you said that you recovered the 5 oz that you removed yesterday , so if you did , then put it back in.
    If you dont know how to put oil in it , you should call someone out that does. A 14 seer system may not have R-22 in it--THE OIL IS NOT THE SAME AND NOT MISABLE WITH THE OIL IN AN R-22 SYSTEM
    I know I shouldnt have even responded to this today but you are about to get hurt and you are definately about to ruin your ac
    Also, If I have to draw a vacuum on it, what pressure should I draw the suction line to before I lock off the service valves. 300 microns do you have a micron gauge?
    http://www.hvac-talk.com/vbb/showthr...threadid=77405
    This is what he was told yesterday when he asked the same question
