Results 1 to 13 of 17
Thread: STUDENT GOING CRAZY
06-05-2005, 12:01 AM #1
- Jun 2005
- NORTH CAROLINA
- 2
WHAT IS THE SEQUENCE OF A FURNACE AND WHAT IS THE SEQUENCE OF A/C FROM THE THERMOSTAT TO THE CONDITIONED SPACE? THIS IS A SPLIT SYSTEM
06-05-2005, 12:13 AM #2
- Apr 2003
- arizona
- 629
you can not go crazy until you have been in the field for a while, look in you ac book under sequence of operation..
06-05-2005, 12:27 AM #3
- Sep 2002
- 4,950
think you need to put in a little more effort of figuring that out before you ask that one in here. If you have any decent book your trying to learn from it will tell you the sequences as Dave says.
06-05-2005, 01:49 AM #4
- Sep 2004
- 3,157
student going crazy? over that question? oh are you in for a treat.
This is agreat place to come to and learn from . The people here will do all they can to explane things to you ---but---you have to have done your homework first. If you cant find the answer in your text book, there are a number of great articals you can learn from in the "for your interest" section
Most of the people you will find here, Teach hvac, have taught , are busniess owners and very sharp techs so you cant get over on them
the sequence of the operation of a furnace or an ac should be easy to find on the net
06-05-2005, 07:24 AM #5
thermostat gets cold, yells down to POS furnace yo i need heat, furnaces runs, thermostat gets hot, yells down to POS furnace ok wise arse shut off.
Can you figure out the a/c sequence of operation now.
Really, the answer should be in your text book, study it. You need to ask your instructor these kind of questions, so he has a better idea of your progress, and can help you better understand what your reading.
Don't expect us to do your home work for you!
We will always help those willing to learn and help themselves.
But you won't learn if you don't try yourself first.
How long have you been in school.
06-05-2005, 07:44 AM #6
Professional Member*
- Nov 2004
- SW FL
- 5,272
Since day 1!Originally posted by beenthere
How long have you been in school.Designer Dan
It's Not Rocket Science, But It is SCIENCE with "Some Art".
06-05-2005, 07:52 AM #7
LOL...
Perhaps I should have been more precise in what I meant.
Quick question for you Dan.
How do you figure out the load of a building, when they have no idea of what they are going to use 2 of the floors for, but want them included in the job?
the envelope is easy, but I can't get anymore info about weather it will be office, storage, or converted to an apartment.
06-05-2005, 08:07 AM #8
Most installation and start up manuals provided with any furnace will give you a complete sequence of operation.
These can all be found online, I know for sure they are on http://www.carrier.com. Sometimes a little tricky to find your way around, go to the website and try this...
click on commercial,building htg/clg systems,products,indoor splits,furnaces. There is everything you ever wanted to know all in PDF format.
Good luck
Live each day like it is your last, for one day you will be right!
06-05-2005, 08:09 AM #9
- Nov 2004
- SW FL
- 5,272
GUEStimating
Just address & install ( extra ) duct main lines assuming office as worst case ?Originally posted by beenthere
... office, storage, or converted to an apartment.
If the space ends up being storage, a trunk line could be "abandoned in place" ( until they convert to more profitable office space).
Is office with personnel, equipment and Lighting the worst case! ?
What else could possibly provide higher interior load?
Guessing is really not an option for installing a FULL system if you wish to protect your reputation.
.. WORK WITH ME .. says the developer.
.. I am trying .. says the Mechanical Contactor.Designer Dan
06-05-2005, 08:19 AM #10
The duct work will be chaised in, so no way to ever get to it again.
If I size for office, and they go aparment, or storage I'm screwed.
I gotta convince them to go 2 stage. But that might not be enough capacity reduction if they go with storage.
No wonder I drink.
06-05-2005, 09:02 AM #11
- Feb 2003
- Huntsville,AL
- 4,125
student: please do not shout online (= don't use all caps!)
student problem: the furnace is a system comprised of several devices, some of which may be repeated for more capacity. Now, what is necessary for these devices to work to accomplish the task, SAFELY? In what order?
beenthere: I would back out -- if they do not know space use, you have no basis for design! I would not be able to design for any service (phone/ lighting/HVAC, ) without more info! Hard enuf when they give some numbers. If that does not satisfy, then find out how big is the budget, spend it all -- worse case would be a computer server center having racks of "heaters". If they will close up the chase to never be accessed again, I would RUN to the nearest door, or inquire where would they like another doorway? Even the better house builders are installing chases for changeout/ modifications!
06-05-2005, 10:02 AM #12
Thanks for the advice.
Can't back out, we do a fair amount of work for this GC.
So its catch 22.
06-05-2005, 10:18 AM #13
Student's guide to thermostat wiring and sequence of operation:
R = Really, like totally juice me with some serious power, man!
G = Gosh, I'm like, you know, your biggest fan!
Y = Yo! Let's get some serious cooling going, here!
O = Oh man, such a flip flopper
W = Why is it so friggin' hot?
C = Commonly, the same path home
B = Befuddled...sometimes a flip flopper, sometimes the same path home
E = Urgent, urgent...EMERGENCY!"In this house we obey the laws of thermodynamics!"
- Homer Simpson
