    SW FL
    Dehumidifier Evaluation / History
    How do you feel about the AprilAire 1700 in service as a Whole House dehumidifier without Outside Air ?
    Capacity ... 3,000 Sq. Ft +_ ?
    [Edited by dan sw fl on 06-04-2005 at 06:39 PM]
    Designer Dan
    Apr 2004
    I just installed a new Aprilair 1700 about 3 weeks ago. RH was between 62 to 74 for 6 years. Now it is between 48 to 52%.
    It does about 2,200 sq/ft. the price I got with LG pump (1 gallon), all duct work (collars to) was too good to pass up.
    Works great!
    Nov 2005
    Northern VA
    I am looking at putting one in for a similar situation.. 2800 sq. ft., no outside air. (house is 50yo, no huge leaks but definitely not tight construction) A supplemental portable dehum placed under the main air return grille helped immensely last summer (though loud and in the way) and during no/low cooling demand (but still muggy) shoulder seasons.
    I'll be interested to see the responses to this one.
    Madison, WI/Cape Coral, FL
    Check out the Ultra-Aire. UA use 6 amps to remove 90 pints vs the 9 amps for the aprilaire. Also better air filtering and controls fresh air ventilation for the UA. Price about the same. UA is highest eff. TB
