Results 14 to 17 of 17
    I like to use a #3 PENCIL INSTEAD OF A STICK. sticks get caught in that metel thing sometimes
    leland nc
    i usaly tie a rope arround the shaft under the medal thingy and pull like i am starting a lawn mower. works every time. the rope has to be ten times the sise of the medal thingy and some times it can stick and get pulled back in. man does that hurt heheheheheh
    make the call and have the unit looked at
    It never fails , whenever I use a rope starter the handle breaks
    May 2005
    Lightbulb
    did you try hitting it with a hammer and shouting obscene things at it. i find that this is especially beneficial. if you do it right, your neighbors will come out to see what the racket is. this will humiliate the unit and cause it to start working! problem solved!!!
