    May 2005
    South Georgia
    Very basic and I suspect broad question, but what range should one expect to see for the coil temp reading found under AC Status in the service menu?
    Thanks.
    I do not know but,I will give a smarty-pants answer and then wait to read what those with more knowledge have to say...
    Between 32 degree and 72 degree.
    I guess it would vary,depending on load.
    Average 55-65 degrees?
    Apr 2004
    Midwest
    Thanks.
    On the infinity control under AC status and coil temp, this is referring to the outdoor coil. The unit uses this thermister to reference several different things, like coil temp vs. ambient …and things like that.
    Your range can go up and down quite a bit; I would imagine you would be seeing something around 120.
    Good luck
    Live each day like it is your last, for one day you will be right!
