Page 12 of 15 FirstFirst ... 256789101112131415 LastLast
Results 144 to 156 of 187
  1. #144
    Jul 2011
    NYC
    i agree with pascone another vote for the bluevac here . changed my whole cough (leaky setup) after owning the bluevac which is so accurate...
  2. #145
    Jul 2011
    Orlando, Fl
    I received my BluVac from trutechtools.com and so far am thoroughly impressed with the item. Backlight is great, having the temp on screen is handy, compact & convenient design. I for the life of me can't understand why an expensive precision meter like this isn't shipped with a case, needless to say I have a small pelican case on the way to house it. But like others have noted, it's very sensitive and helped my get my vacuum system snugged up where as a yellow jacket led gauge I used as a comparable showed a very different reading.
    Consider this another thumbs up so far.
  3. #146
    Oct 2010
    The very humid south
    just ordered mine hope its as good as y'all say it is.
  4. #147
    Jun 2011
    Hello,
    i have big problems with OIL sensor...i can not rid of the OIL on the screen.I clean and clean but no luck with it.What exactly can i do to fix the problem?When the screw cap is on I got an error OIL.
  5. #148
    Aug 2010
    Coral Springs, Florida
    Quote Originally Posted by deko81 View Post
    Hello,
    Hi, Deko.
    Do the freezer calibration...everything should be ok after that. Let me know if you have any additional problems.
  6. #149
    Jun 2011
    Unhappy
    I tried this also but it still shows oil.
    And my bluvac after calibration perform the functions itself that looks just like i would pressing the keys but i dont.Light go on and of and other stuff.
    I have issue with it from the first day.Maybe i m doing something wrong i really dont know.
  7. #150
    Aug 2010
    Please call me at the office first thing monday (954) 227-0781. Ask for Joey.
  8. #151
    Jun 2011
    Can we please discuss here or on my email, because i m from Slovenia and i
    dont talk english very good.Do you maybe know where can be a problem?
    Regards, Dejan
  9. #152
    If english is tough do you have any pictures or video?
    Is it the oil indication in tiny print or large print?
    If you turn it on but hold the power key down what does it say?
    From what I understand from your posts it reads microns when connected to vacuum and all the functions work fine except the display reads oil in tiny print.
    Is that correct?
    I had this and after the freezer calibration it went away.
    I didn't notice any issue with the micron reading either way but the BluVac was telling me to calibrate soon.
    If it happens only when the cap is on could the cap oily
  10. #153
    Jun 2011
    OIL in large print.
    If i turn on it says Soon and than OIL
    Now i can not calibrate it at all because i can get it to Cold...and then went to beep and on screen is -OIL-.I did clean several times with alcohol and no luck.
  11. #154
    Aug 2010
    OIL in large print.
    Deko,
    Please go to http://accutools.com/index.php?page=contact and send me a message with your name & email address (and phone number if you can). Also, include the serial number of the BluVac (printed inside the battery compartment) and the name and location of the distributor you purchased it from.
    From your description, it sounds like your BluVac is not working properly. I am sorry that you are having problems, and I would like to help you get a new one as fast as possible.
  12. #155
    Feb 2007
    Central NJ
    guy i work with went to use his on friday, only second time using it and its as dead as a door nail. how much are these things again?
    You have to pay your due's before you pay the rent!
  13. #156
    Aug 2010
    Quote Originally Posted by n-e-w Jerz! View Post
    Hi, Jerz.
    The BluVac works as we say it does, though I understand that you have no reason to believe me or trust in what I say about it.
    If Deko's BluVac is truly not working, which I suspect is the case, it will be only the third confirmed defective unit of hundreds that we have shipped since its introduction in October of 2010. I am taking personal responsibility to ensure that Deko has a properly functioning unit as soon as possible.
    If your friend contacts me, either via phone, or through our web site, I will ensure that he, too, has a 100% functional gauge. I have no desire whatsoever to have material in the field that is not functioning properly.
    Our gauges are built and tested here at our factory in South Florida. We have stringent process and quality controls in place to ensure that material shipped meets or exceeds our published specifications. Unfortunately, occasional defects may occur, even under the best of conditions, but we will always do whatever is necessary to ensure that our products reflect well on our company.
Tags for this Thread
